Hi!
So I’m testing out an alert from NewRelic to Pagerduty using the NewRelic -> PagerDuty service integration.
So I’m trying to use the Event Management -> Service Orchestration Rules for the PagerDuty service, attempting to get PagerDuty to parse the custom_details for NewRelic priority (with a space, unfortunately), if the value is “HIGH” -> set severity to “Warning”, then use the dynamic notifications to alert based on severity-> urgency (warning -> low urgency, default is severity “critical” -> high urgency).
I was able to do with this a Splunk integration, having some trouble with the NewRelic integration.
Can someone spot check my event rules:
event.custom_details['NewRelic priority'] matches part 'HIGH'
given this events API json payload:
"client": "New Relic",
"client_url": "https://one.newrelic.com",
"contexts": [
"href": "https://radar-api.service.newrelic.com/accounts/1401137/issues/<SOME_KEY>?notifier=PAGERDUTY_SERVICE_INTEGRATION&action=",
"text": "Issue Page",
"type": "link"
"description": "Janus--ethos51prodva6---infra-janus query result is < 3.0 on 'TEST,IGNORE - Janus Response time in POST /janus/v1/sidecar greater than normal'",
"event_type": "trigger",
"incident_key": "<REDACTED>",
"service_key": "<REDACTED>",
"details": {
"Alert Condition Names": [
"TEST,IGNORE - Janus Response time in POST /janus/v1/sidecar greater than normal"
"Alert Policy Names": [
"Janus-Alert-Policy"
"Description": [
"Policy: 'Janus-Alert-Policy'. Condition: 'TEST,IGNORE - Janus Response time in POST /janus/v1/sidecar greater than normal'"
"Impacted Entities": [
"Janus--ethos51prodva6---infra-janus",
"Janus--ethos51stageva6---infra-janus",
"Janus--ethos11stagejpn3---infra-janus",
"Janus--ethos11stageirl1---infra-janus",
"Janus--ethos02stageva6---infra-janus",
"Janus--ethos11stageva6---infra-janus",
"Janus--ethos03prodva6---infra-janus",
"Janus--ethos03stageva6---infra-janus",
"Janus--ethos53stageor2---infra-janus",
"Janus--sensei56stageva6---infra-janus",
"Janus--ethos02prodva6---infra-janus",
"Janus--ethos12stageva7---infra-janus",
"Janus--sensei56prodva6---infra-janus",
"Janus--ethos12stagenld2---infra-janus",
"Janus--ethos11stageor2---infra-janus"
"IssueURL": "https://radar-api.service.newrelic.com/accounts/1401137/issues/684d494d-b1ea-40e9-8e1f-86d59e69f8ce?notifier=PAGERDUTY_SERVICE_INTEGRATION&action=",
"NewRelic priority": "HIGH",
"Runbook": [
"https://git.corp.adobe.com/adobe-platform/ethos-runbooks/blob/main/janus/sop/troubleshooting.md"
"Total Incidents": "15",
"Workflow Name": "Policy: 3563713 - Janus-Alert-Policy",
"id": "684d494d-b1ea-40e9-8e1f-86d59e69f8ce",
"isCorrelated": "false"
I believe I’ve interpreted the events notifications path correctly based on this link:
https://developer.pagerduty.com/docs/ZG9jOjM1NTE0MDc0-pcl-overview#paths
and that it seems in the API Event json object, details top-level object seems to what is contained in the custom_details in the event rule.
LMK If any of that’s not correct or I’m missing something, thanks!
